1 - 13 of 13 Posts
Hello guys, i want to retrofit an air condition system, maybe vintage air system. Does anyone have an easy solution to suggest?
Sent from my LYA-L29 using Tapatalk
When it comes to adding air conditioning to a Montreal; I don't believe that there is an "easy solution". IF, your car came with factory air, you would have a big head start but that is probably not the case or you wouldn't be posting here. Bruce Taylor in 'Alfa Romeo ~Montreal the Essential Companion' shows all the parts required for the factory A/C system and there are a lot of bits and pieces!
The listing for the $176,000 Montreal, sold at auction in Scottsdale AZ, mentioned that all parts for an A/C system were available to the winning bidder (for additional $). Apparently the 'buyer' was not interested in the system and all the parts were listed and sold on eBay. You would think that if anyone could update a non A/C Montreal to A/C, it would be the owner of one of the nicest examples ever...surely someone has installed a working A/C on a non A/C car. Must be a big job...
A couple years ago a good friend installed a 'Vintage Air' system on his Alfetta. He commented this week that the system is working well. It was not an easy job. He wanted a factory look and told me his budget for the job was $4K -he did all the work himself. I believe that he come in under budget. The Alfetta has a ton more space in the engine compartment than the Montreal.
Should you continue with your quest; I wish you much success.
Mark
I'm seriously thinking about taking on some type of A/C conversion with my 1971 Montreal at the moment, since I have the engine and Dash out of the car at this time.
Now would be the time to do it! Regret and the time/effort it will take later would be a punishment! >:)
Reactions: mtbjeff
I owned a 1972 Montreal in the late 1990’s for 5 years. It had factory A/C. I was a wast, The A/C vents were on either side of the center console. Near you knees, the speed of the fan on Hi, was so slow that it felt like a 90 year old with lung disease blowing air on you.
If the car was in the garage and I turned the air on, then backed out of the garage,it could keep the car cool for a while. But if the car was sitting outside and it was over 80 forget it. The front windshield is like a green house. I always felt that replacing the stock compressor with a new small Japanese rotary compressor and updating the fan motor under the dash for something with higher rpm’s would be a start I was told by a few Alfa guys that a lot of the parts were similar to a GTV. The A/C condenser sits on the left side of the engine compartment up near the radiator with a small little yellow fan behind it. I would think a good AC shop would be able to fabricate something with the money would be is another question.
Hey, Demstav. I wouldn't try to do anything if I were you, I had some problems with air conditioning, it wasn't working properly and I tried to repair it but it stopped working at all. I asked my family about this issue but no one could help me out, so I decided to use Google in order to find something there about fixing my problem but I didn't find anything suitable. One day, my friend advised me to use a site, he said that they provide qualified air condition repair service. I can say that they really helped me because their repair fixed everything and my A/C started working properly again.
I'm terribly sorry for posting here but I want to retrofit my system too so I'm wondering if you @Demstav did something
I’m working on one at the moment, not finished yet
Hello All
I have a complete Engine bay part of the Air Condition system in excellent condition for sale
As the other users said, there's no easy solution.
Anything you install is bound to have retro effects on your other parts, be it whether you install a Zero Breeze 2000 or a Razor 25. I would suggest calling a car workshop or car dealership agent to help you with this problem.
Sincerely,
Air Con Car Specialist Engineer @ SGHomeNeeds
1 - 13 of 13 Posts
