Greetings again! can anyone with GTV aircon measure their condensor? I'm having a hard time finding a new one that will fit in there. If the air intake horn wasn't there it would help but I like it. The height of the radiator core is right at 15 inches and the width is 17 1/2. They are usuall about an inch thick and if it goes right up against the radiator it might slip behind the air horn. I'm assuming:) the hoses go through the left side at the bottom where there is an opening to the engine compartment. It also appears that there are mounting tabs already there. Any help would be greatly appreciated.
Can't thank you enough, Thanks!
