Do you have dco3 or dcoe carbs? There are two styles airboxes used on Giulietta Veloces depending on the Weber carbs you have. I have converted a Giulia veloce lower airbox by cutting out a section and tig welding it back together. The first two photos are the modified Giulia veloce airbox. The last photo is the DCOE2 airbox. If you are interested in the modified Giulia airbox send me a pm. The airbox was used in my Spider with no issues for many years. You do need the proper veloce motor mounts to give you the additional clearance.
It is for dcoe2 giulietta. Your work looks perfect. I almost don’t have room for an airbox so it must be slim
I used the modified 1600 airbox in a 1960 101 Giulietta Spider with veloce motor mounts with no interference issues.
