Good point....I'm hoping to get in there with Por15 followed by cavity wax after paint. I used Por15 in some other recessed areas on the chassis and it seemed to flow (or wet out) and creep pretty well in some of those areas....If/when you have this area dipped in acid to remove rust which will require water washing to neutralise the rust what will you use to protect the inner spaces which will want to re-rust....
Yes and no....the outer skin flange folds down over the inner frame flange only. The extra member that forms the box does not get sandwiched in between these two. If you look closely at this photo you'll see that there is a joggle (or step) in the frame flange and the box section sits in that joggled area...when the door skin goes back on does the lip fold over the same edge and is it triple layered then? please describe I'm not clear on this area. Finding spare,scrap NOS stamping shapes is neat way of simplifying your work load.... very smart way to get there...
