My plugs have a similar look with #1 being a bit darker. I checked them last year, I have not checked this year.
Good to know.....for some reason I was thinking that the FI was running richer....but it looks like it's running nicely at speed at least. Warm idling is still not as smooth as I'd like it to be with the tach needle bouncing a bit...and quite often pulling away from a stop it feels like the engine is misfiring. So maybe idle mixture on the FI pump needs another look see...My plugs have a similar look with #1 being a bit darker. I checked them last year, I have not checked this year.
For cars that are not listed....the App allows the manually entry of the necessary data and proceed as normal after that. There is an excellent youtube channel called Weberauto with a very knowledgeable presenter called John Kelly, who was involved with the development of the NVH App. He describes in detail how it works in one of the videos.....Interesting link thanks for sharing that. Have you heard from anybody firsthand? I noticed it asks you to select the vehicle - wonder if they do fifty year old Italians?
I must admit that I simply rebuilt my driveshaft by replacing the u joints without really checking the centering of the joint after installation. Here too John Kelly has a great video (6 parts in all) outlining how to do the whole job correctly.....I believe we discussed drive train balancing on another thread I posted the rather large patch my machine shop welded to the pressure plate to bring it into balance. That and rebuilding the driveshaft joints has given me a nicer ride.
Thanks confirming that for the other cars. For the 1969 US cars, the parts manual (from my experience) has been accurate and invaluable during my restoration...10mm hex nuts all the way thru to the S4 Spiders. The parts book doesn't lie.
Just go with what's in the factory parts manuals and questions on correct configuration can in most cases be easily resolved...So many experts ...Not looking forward to these inevitable conversations
Rossano, I can't tell in your photos here but are the suspension bolts black oxide or zinc plated please?Body color on the underside is not a top priority for me at this point in time.....( I've gone backwards on too many occasions on this project). I 've progressed on both sides of the front suspension...the usual work was completed on these....strip, blast, paint, new bushings, seals, rotors machined, ...etc. etc...Koni Reds....no magic here....simple simple.
Brake calipers calipers were the next mini milestone for me...but not for the disassembly / reassembly aspects. I've been staring at these calipers for years! and was always putting these on the back burner till now.
My plating system's power unit is at the limit of amperage (5A) for parts the size of half of one rear caliper. But the end result was not too bad ...for an amateur. The front calipers on the other hand are much larger and so I would have to either plate half of one of the calipers halves at a time...or look for a bigger power unit....one that can output 10A.
