My recently rebuilt 2 liter Engine (spider 2000, 1976, dual Webbers) has a 10.3:1 CR.
This was not planned. During the rebuild (new cylinders, liners, valves, etc) the block was milled a bit due to some corrosion. My mechanic tried to fabricate some sort of shim made out of a thin aluminum sheet, but it did not work. It leaked under a water test.
So the CR ended up bumped to 10.3:1.
Our normal gasoline is 92 RON (it will be 93 RON in 2022). Sometimes, when starting to accelerate in 2nd gear I can hear some fast cracking noise which I believe is pre detonation. If I press the foot down faster the noise goes away.
So, here’s the question. Would getting one of those electronic distributors (eg 123) would allow me to further adjust the spark timing to eliminate the pinging?
The pinging does not appear very frequently, most of the time only when passing through the 2ng gear in the highway, but at the same time I know it can wreak havoc in the pistons, rings and why not. I’d like the engine to last.
Gui
Gui
