Put the car on stands and remove rear wheels.
1. Put the handbrake handle in its horizontal position and make sure it can't move
2. Turn the rear hub until the star wheel appears in one of the holes in the hub
3. Use a flathead screwdriver and click-turn the star wheel. Left to tighten, right to loosen up. See arrow in attached picture.
4. Continue until the brake shoes touches the drum and back the star wheel off one click or two
5. Adjust the cable (i.e. take up the slack) with the adjuster in the propshaft tunnel. The cable should be tight, but not so tight that the handle starts to move. You may have to remove the cotter pin and turn the clevis if the cable's too slack.
6. Check that the handle just barely engages the brake shoes against the drum (or the handbrake telltale engages) when in notch #2. Repeat step 4-5 until it does.
The reason for step 6 is that you want to engage the brake as early as possible so that the handle travel don't become too long later, when the pads wear out or the cable stretches.
Did I forget anything?
