I am removing the ac from my 84 spider. Not sure what to do with the hoses going into the firewall. Can I disconnect them pretty easily under the dash?
If you remove the compressor on an S4, yes, you'd need a shorter serpentine belt. I think these cars were sold in Europe with A/C as an option so probably the right belt is available. RockAuto may have the correct listing.I have considered doing the same thing to my '91. My mechanic says the engine belt would be different. I was also wondering if removing the interior plate in the air distribution box would restore real air flow to the floor and vents?
.....afaik, no euro S4 had A/C.....I have only seen/heard of A/C on import vehicles (USA or Japan)If you remove the compressor on an S4, yes, you'd need a shorter serpentine belt. I think these cars were sold in Europe with A/C as an option so probably the right belt is available.
