1 - 2 of 2 Posts
Serpentine belt broke while driving supposedly compressor seized CAR overheated 3-4 minutes can i bypass pully on compressor or 'break it so it spins' ? Cannot find used/new one what is size in mm for a gates belt to bypass compressor? When CAR runs slight tapping noise beneath valve cover lid help!! Also car wont start without shocking starter (could cut off switch be on since CAR came with alarm(keychain has square alarm type button original from alfa 164l 1995 call me 4107130065 or email [email protected]
Join us over under 164 section. Sounds like compressor clutch pulley bearing froze up on you. Not sure you can bypass compressor pulley with shorter belt.
As for shocking starter to start car where are you doing it at false firewall connector? You may have bad red stripe relay with diode starter relay I10.
1 - 2 of 2 Posts
