So I have invested time and money into a new abs pump and new accumulator from GM that was successfuly used in previous threads described. However, I am having trouble getting fluid out the line from the master cylinder and into the abs pump. The abs pump is connected and my fear is that the new pump will burn out if I start the car up too many times. Should I be worried about a pump burn out?
Should I replace the abs master cylinder with a good used one? I have unscrewed the bleeder screw behind the reservoir on the master cylinder and no fluid is coming out? What to do next to keep the ABS in working order?
