Extrude-Hone
I have used this process a couple of times and while I don't have a dyno, it is a proven reliable and relatively reasonable technology originally developed by GE Aerospace.
Your head, manifold(s) are mounted on a an extruding abrasive polymer pump. As this flows it naturally follows the hydraulic pathway and removes material in a fashion similar to airflow. The results are impressive. The process mates manifold flanges to engine gas inlets/outlets. As it follows physics as opposed to what a manual porter may think is the best mechanical means to enlarge and reshape ports, the results follow the laws of fluid/gas flow dynamics.
OEM manufacturers are now using this tech.
Cheers, S
Cheers, S
