Can any one tell me if it is possible to replace the door shut panel without removing the wing? It looks like it may be tacked around the wing and not seem welded? appreciate any knowledge on this..
What you could do though is cut the wing over the full height, remove the shutpannel and but of wing, remove the wing bit from the shutpanel, weld in new shut panel, and reweld the edge of the wing to both the wing and the shutpanel.
Big job, yes, but doable if your only option...
