What's the electrical connection next to the overflow? The reverse switch is in the bellhousing so far as I understand.
Which way does the springgy clip thing by the throwout bearing go and what exactly does it do?
Can grounding straps be cleaned up and retain their functionality?
Seat belt interlock switch, I think.
The spring is a retainer. The ends go into the TO bearing carrier, the part around the pivot holds it in place. Once all installed, doesn't really matter than much, and they're often broken/backwards/missing.
You need to ground the engine/trans to the body somehow. That looks like the original strap. Typically come off one of the engine/trans bolts, some rear plates have a separate tab for the bolt.
Interlock... that explains its absence on the euro parts diagram!
The retainer is a nice touch, I suppose its doing the job done by duct tape while installing clutches on other cars I've worked on..
