1 - 2 of 2 Posts
I have recently had a new compressor and dryer installed along with a new expansion valve. The A/C works when you start the car for approx 5 min. then stops blowing cold air. Once in a while it will stay with the cold air. Mechanic then replaced the temp sensor in the cabin and the temp sensor in the dash, still intermittent.
I have checked the the system for codes when it is not blowing cold air. No fault codes on system self diagnostics.
I did check the outside air flap and it is opening and closing as it should.
Help.
Thanks Phil
1 - 2 of 2 Posts
