Does anyone have any tips on separating the compressor from the engine without cracking open the A/C lines?
I'm pulling the motor and I don't want to have to deal with evacuating the system.
The whole area is covered in years of oil from a leaky head gasket so there might be bolts/nuts that I don't know about or see.
I've done a search and could not find any how-to's, just people referencing that they had to remove the compressor.
Thanks for any help!
I removed my compressor a few weeks ago. You have to remove the 4 bolts that mount it to the bracket. I had a hard time just getting it out of the engine bay even with the hoses disconnected. Once I pulled it out, I was able to remove the bracket mounted to the engine.
It sounds like you just want to remove it from the bracket and then remove the engine. I am not sure what kind of space issue you will have. The compressor is big, heavy and bulky. I wouldn't leave it handing on the hoses.
Sorry, that is all I can tell you.
Well I finally figured it out, although I don't know how its possible with the engine fully seated.
I got the other 3 bolts out with some grunt and the last bolt (bottom-front) was a huge PITA since the pulley is in the way so you can't put a socket on it. After some swearing and wrench-slipping knuckles, I finally persuaded the last bolt/nut to let loose. It's currently zip-tied to the radiator support bracket to keep it out of the way and also to keep the compressor from pulling on the old hoses.
I'll be getting into mine soon as I'm making a pair of slotted brackets for the top bolts so I can adjust belt without screwing with the crank pully.
I've been into it once already and with radiator out it's not impossible to get that bottom bolt, but I think it's less of pain to do as you said and just disconnect the motor mount and raise the engine a couple inches.
