OK here is what I have, no power to the GRN-BLK wire to power the compressor. With gauges I have Freon, at rest 70 psi high and low side same (compressor not on). It was cooling OK after I put in one can of Freon a few weeks ago. I went in and swapped out the compressor clutch relay behind the dash, no change. I can hot wire 12V to the compressor and it kicks on and begins to cool and then the rad fan kicks on as it should. I also disconnected and reconnected both large round connectors behind the false firewall. Jumpered at the three way switch and that does not turn on the compressor or the rad fan from either connector. I of course checked the fuse for the A/C as well. Do I have a bad temp control panel? This issue just started yesterday. No trouble codes from the temp control panel either running the self diagnostic. Any help would be appreciated.
Charles
Charles
