this is the fan relay, 30A fused
search for a BITRON B047, or MP 2335, Valvar 2335 or the original alfa PN 82461829 someone will have one, either used or new
you sometimes find them new old stock in Italy (the Lancia Integrale used the same relay)
that Canadian ebayer (311) has a used one for 65$ (usual high price for him)
an ebayer out of NM has a used one for 20$ (ebay # 164591527503 )....that is fair.
As said above, try APE maybe first.
I suppose one should first ask, what is wrong with yours? you have obviously checked the fuse is ok?
are the fans not coming on, have you bypassed the sender on the radiator to test if the fans work?
you often see cross reference parts from Hella or Bosch purporting to be a direct drop in (albeit unfused) for this MP relay, but you might well find the pins are swopped over!
this is the pin configuration of the original relay, note the position of pin #30
Hello,this is the fan relay, 30A fused
