Pull down on the plastic ski hole. cover You will find 2 or 4 screws there that hold it. There is also a bag that the ski's go into so take pictures if you can't remember how to put it back together. The bag goes in first then the back cover. Use a skinny punch to keep things aligned as you put in the screws. It can get really frustrating trying to hold all of that together.
Thanks!
Those four (4) "screws" on the 12v 164 models located around ski boot door opening are white push nylon buttons. If same on 24v model use a V-forked trim tool to pop them out.
Be carful removing as not to break the compressed particle board. You can typically re-use the nylon press in bolts. Do you have a new sender or trying to repair old one?
I repaired my original one but would like a spare. Do you have any for sale?
Hi, have you solved this now?
On 24v models there are no press in nylon 'bolts' for the ski-hatch board/trim - all screws, accessed from the interior via the ski-hatch. Let me know if still working on this and will upload some pics.
Discussion Starter #8 (Edited)
I figured it out myself eventually and you’re exactly right. I’m actually thinking of replacing the steering rack myself. I haven’t replaced one yet so any tips would be appreciated.
