The light has come on and had the clock spring replaced with a good(?) one from another car. Still have the light. Disconnected the battery for over an hour to drain any memory. Any thoughts?
Jerry unfortunately the Air bag light on 94-95 164 is set into Nonvolatile memory in the Air Bag ECU so no amount of battery on/off will reset it. The ONLY way to reset is with the marelli tester or a surrogate.
if you are close enough to dean Russell at trail auto he may have the tester....
