What?Watt? "Found that valve cover seals must be replaced, adjust valves, replace plugs" These don't raise compression, Only valve adjust if valve clearances 0.000" and then it is to late as valves will be burnt.Hi! Steve,
Thnak you....Yes compression was checked after runninng the car...Found that valve cover seals must be replaced, adjust valves, replace plugs ( soaked with oil) and possibly more
Ron
