1 - 2 of 2 Posts
So I decided to do the head gasket on my 91 Spider but first I pulled the motor and tranny just to clean everything and make it all pretty. Replaced a bunch of stuff then slammed it all in.
Only prob was the sensor on the tranny bell-housing is missing the connector now.
Everything is back together but now the motor turns but wont turn over. EVERYTHING is in place.
Just need to find out where the bellhousing flywheel sensor connects.
The one on the crank is plugged into its connection so I repeat again. Just trying to figure out the one on the flywheel.
Thanks in advance!!
i can't think what flywheel sensor "on the bellhousing" you mean?......the 90-94 Motronic spiders only have one crank sensor, and that's up front on the timing pulley.
The only wires coming out the bellhousing are the two for the reverse lights (the reverse light sender is inside the bell housing)
1 - 2 of 2 Posts
