Servo on the bench with duct tape covering hole and vacuum applied to the valve. It is maintaining pressure. Is this an adequate check for the booster?
You covered hole where master cylinder mounts and applied vacuum through hose going to engine with check valve installed in booster? If vacuum holding I would say it is good.
