Hello, I posted here a while back about my 89 spider that would not start. I've been trying to diagnose the problem, and the car still will not run. I've done a lot of work since my last post. Hoping an experienced owner can help me out.
Here is what I have done:
1. Confirmed that ignition system works using a spark tester.
2. Confirmed that fuel pump works, and fuel is going through fuel rail.
3. Confirmed cylinder compression.
4. Drained entire gas tank, and refilled with fresh gasoline.
5. Confirmed that FI ECU is working properly with noid lights.
6. Engine will run for a few seconds if I spray starter fluid in air intake, then dies.
7. Battery is new and fully charged.
At this point, I am guessing there is a problem with my fuel injectors. Any other ideas?
Thank you,
Greg
Thank you,
Greg
