1 - 2 of 2 Posts
FS 89 Alfa Spider Quad w hard top
I am selling my nicely cared for and always garaged 1989 Spider Quad with
88k miles on it. Here is a partial list of what has been done to it since I purchased it with 56K miles in 2000. This is my second Spider, the first one I owned and drove every day (100K miles) from 1989 to 2000.
Here's the list-
Installed Kenwood CD Player with Amp and Boston Rally component Speakers-
moved speakers from doors to front kick panel (sounds great) 56K
New soft top, Door seals, Speedo cable 56K
Magnaflow center muffler, lower radiator hose 56K
New cylinder head at 57K
Clutch, center support & bearing, both u joints, ft/r trans seal, tail pipe 59K
Clutch master and slave cylinder, Lambda Oxy Sensor 60K
Electric antenna motor, engine belts 65K
Master break cylinder 71K
Distributor cap/rotor & plugs 73K
Lower ball joints, Idler arm, LF inner tie rod, RF upper arm, align front end-
-rear coil spacers, complete chasis set up, 77K
Intake pressure sensor 81K
Front/rear brake pads 82K
Set of Goodyear Eagle GT HR Tires 195-60-15 82K
Gas sending unit gasket, vapor check valve 84K
Soft top seals 85K
valve job at 86K
Rear flex brake line 87K
Leather shifter boot, replaced inner bolster panels on seats, 87K
Oil (Redline) is changed every 3,000 miles
There are other incidentals but I think you get the picture that I have carefully maintained this car and currently it runs and drives great, just get in and go! It is a blast to drive!
I am asking $8,000.00 US dollars or best offer.
email me, [email protected] (you will need to wade thru my spam arrest) or call me at 206-723-0949
Talk to you soon,
John Smith (yes, that is my name...)
1 - 2 of 2 Posts
