All you need is some threaded rod, washers and nuts. You remove one bolt from the spring pan, and replace with threaded rod, then the next in turn until all bolts have been placed with the threaded rod. Once the bolts have been replaced, you keep loosening the nut until the spring has been let down entirely.
