88 Spider Rear bearings
406 Views 5 Replies 4 Participants Last post by  Villalji
Hi there, starting the restoration of an 88 Spider, and I noticed a bit of play in the rear bearings, is this normal, or do I need to change the bearings... or can it be fixed?
thanks for any advice you can provide!
Vídeo link here
That sound is coming from the LSD and is normal.
When you put the tire back on and test the rear bearings, you will also find a little play and that is normal as well. Fronts should have no play.
Good luck,
Vin
Reactions: 1
As above: the bearings have play from factory new, as long as they don't feel rough or the play is excessive its normal
Reactions: 1
your brake disc seems to have a rather deep groove worn right in the centre
Thanks for your answers, this gives me peace of mind!
Reactions: 1
thanks for your comment, i noticed the groove, and I was planning to change pads and discs anyways.
