1 - 2 of 2 Posts
Having connections behind fuse panel under steering wheel. These look like simple plugs in the back. Is this correct? Any tips from someone who has cleaned these contacts before?
Thanks for any tips.
They're "snap-in" female terminals that lock into place in the hard plastic of the fuse box. What makes you feel they need cleaning?
I wouldn't bother trying to pull them all out. Vacuum as best you can (careful not to knock anything out), and use an air compressor to blow out any remaining dust, etc. Then, one at a time, pull the relays and spray contacts liberally with contact cleaner, working the contacts in and out.
That should do it!
Don
1 - 2 of 2 Posts
