Hi everyone, I'm hoping I'm posting in the correct forum. A little background info, i have an 1987 spider veloce, been trying to restore it for the past 6 years now, I've rebuilt almost everything on this vehicle, even hopped up the engine. Currently I'm stumped right now my car has no fuel injector pulse at all all the grounds are there and all the power is there i was suspecting a bad ecu so I went to a local shop and have them test it on their spider and it worked fine, can a napa fuel pump relay make all the difference, also I tried going for an electronic distributor but that went up in smoke so now I'm using a points distributor and I'm aware that that battery voltage has to be above 10.5v, tts works, cold start injector works, main injectors work. If anyone can help me with this issue I'll be very grateful. And also the noid light does not blink and both wires at the injectors have power.
