Here are the facts:
Horn wasn't working, took the steering wheel off and trouble shoot the problem. While I had the steering off took off the cluster and replaced lights and cleaned the lens, put back everything horned worked perfect!
Took it for a ride and everything good. After one mile or so I felt ther was no power. Car was on but it wasn't reving up as I pressed gas pedal, went into a parking lot, car still on but no power, pressed the gas and slowly car died!
Took one of spark plug wires and I felt and saw spark,( so I have spark), wrongly I took the return fuel line and I saw no fuel, so first impression was fuel problem, tried listening to the pump and couldnot hear it click. So had it towed to the house!
Took the pump out and while trying to clean it and testing it connected it directly to the battery and saw it working! Ok maybe pump was stuck. Put it back and now I feel the pump come alive and vibrate while trying to start! But no start!!
Took one advice and replaced the spark plugs but still no go. I see voltage on all injectors except the cold start which is normal I think since its 60 here in Texas! I have around 10.7 voltage on the battery when trying to start and I have checked all of the fuses to the best of my ability. I have to get a gauge to check the fuel pressure next I think!
Any other advice is greatly appreciate it! Thanks team!!!
