I have a 1986 Alfa Spider. Engine will run for 5 sec then stop. I have spark at all clyinders. Fuel pressure at fuel rail is o.k. Also ran fuel pump direct with same results. Car had just been running fine.
If I unplug the injectors (the three I can get to) there is no change. Can I check the voltage at he injector.
Also can I check the Main Relay?
Help!!!
