1 - 5 of 5 Posts
Hello all
I had a question regarding an 86 spiders a/c. First of all id like to know what the refrigirant capacity is. Second, There are 2 ports on the compressor, Suction and Discharge with an additional port on the receiver/dryer, Where do you folks hook up the high and low sides ? Thanks in advance.
suction is low side, discharge is high side. You can connect high side to port on receiver/drier.
Regarding capacities, I do not know. HOwever, with R-12, you'll be real close if you charge the system on a warm day, with top down, and a/c on full cold (with fan on hi) and charge until bubbles in sight glass go away...
i filled her up from empty. took 3 cans of Freeze12 and a single bottle of Esther100 (alfa recommends sunoco brand. but the napa stuff worked fine)
1 - 5 of 5 Posts
