Battery is good, tried 3 different ones.
Voltage 14.3V, after one crank voltage less than 12V, 2 cranks and battery is dead. Starter cranks fine.
Has had regular maintenance by seasoned Alfa mechanic. Tuned and good until now. Just can't afford to take it back at the moment.
I think I flooded it at one point, I could smell gas, guess that means fuel pump works. Fresh fuel.
Newer stuff; cap, rotor, plugs, fuel filter, etc. (via mechanic)
Visual inspection good, no bad hoses or air leaks found. Connections look good. Fuses all good. New battery cables.
What else to look for?
