I am having a problem starting my 86 spider, I retimed the vehicle TDC/Lobes facing out/distribuitor at #1 cylinder. No pop or starting activity even with starting fluid sprayed into intake. I have not changed spark plug order. Spark activity but no way to check if it is correct.The motor was rebuilt by a local mechanic (5 years ago) that I lost confidence in after he tried unsuccesfully to turn the distributor, and I had it towed back to my house. The question that I have and I have not seen in previous forums threads is.... Can the flywheel be put on the motor in the wrong position. Can it be 90/180/270 degrees off? I understand there is a mark on the flywheel for TDC and the sensors. Before I take the tranny off can I get some suggestions? I have checked all other items swapping parts with my 85 spider which is running fine ALL Thank you in advance, I will not outsource rebuilds in the future, I rebuilt the 85 successfully by myself this summer after local help to get it running 2 years ago(thank you Skip).
Joe
Joe
