The 7.5 amp fuse(white) keeps blowing when I turn on parking lights, This is fuse # 9, which circuit is RH front parking light & side marker, engine bay light, and LH rear parking light & LH rear side marker. It worked just fine a few months ago. It appears to have a direct short; I have wiring diagram & have changed all inop bulbs, + repaired the trunk mounted stop
light so it now works. Only other modification was to cut power wire to power mirrors, as they never worked, and to unplug clock as it never worked either. I attached my ammeter to #9 fuse, turned on switch & observed a draw of just over 7 amps. Connected test light to upper & lower fuse contacts & the test light lights up. All other lights, including the glove box & courtesy floor lights work as supposed to. Next, I am going to try the 16 amp fuse; would appreciate any suggestions. BTW, the RH & RR turn signals work fine. HELP!
Chief Bre
Chief Bre
