1 - 13 of 13 Posts
Changed the fluids last week. The only way I could get the Oil Filter out was to remove the air filter, and the air filter box and bring the filter out the top. Is that normal?
That's the only way if you are using the larger oil filter.
If you have the smaller one, it can be pulled out from the bottom, but what a mess.
IMHO, you are doing the right thing, larger filter and out the top.
Vin
That's the way I always do it*. Somebody said they could get it out from underneath. Either they were lying or had a small oil filter.
*actually, I also use a disposable diaper. Position it under the filter - on top of the part of the sump that sticks out under the filter area. It collects 99% of the oil spillage from the filter.
Discussion Starter · #4 ·
Thanks for the responses. I thought maybe I had and extreme engine sag, or there was a trick I didn't know. Eric, thanks for the disposal diaper advice, but I am not quite there yet! I just used an old shop towel.
I always do mine from the bottom using a K & N filter. I like the idea of the diaper to minimize the mess, but aren't you showing your age? :D
ghnl - wonderful photo.
And a forehead slapping simple solution to the drip problem. I'm off this morning to buy a box of diapers while I'm thinking about. Plus I need a Mother's Day card.
love the diaper idea. Just love it. I've used bread bags w/luck to corral messy stuff and saw something in a magizine Family Handyman maybe, that was a roll up kinda oil drippage guide thingy that looked effective but I reall like the diaper suggestion. Chris
Top is good for me- you dont have to get on the floor (bad if youre an old guy), and I use newspaper- stuff them under the filter against the engine- very clean. Plastic bags is geez, I dunno, they done even absorb anything.
What a mess though. EWven with absorbent paper/rags.......hey, if you use synth, at least you prolong the change intervals vs dino oil.....
I made a little "diverter" out of a scrap piece of flashing. It goes under the filter and drains the oil down into the catch pan. Just slide it under there before removing the filter, no mess.
The manual for my 84 shows that you swap oil filters from the top. I have done it both ways and now do it from the top every time. Changing from the top is no big deal time wise and allows me to take the air hose to the air filter and box while I have it apart.
1 - 13 of 13 Posts
