1 - 5 of 5 Posts
I'm replacing the rubber intake boots and various other odd's n ends and I came across this braided ground strap just dangling off the block.
Is it suppose to be a ground on the starter or did it come off some of the bolts while I was removing the intake plenum and other parts and pieces?
Les
Discussion Starter · #4 ·
that's exactly it... thanks
When I was removing the plenum and fuel rail, I noticed that there was only 1 13mm bolt in place and there was nothing other than a washer on it. So... another gremlin found and will be fixed when I get my refurbished fuel rail and injectors back from OK injectors and get this all buttoned back up.
The closer I look at the ring terminal of the strap, its obvious it has not been attached to anything for quite some time as it is badly covered in years of typical grime. It will get cleaned back up and bolted back into place.
Les
Mystery solved in 45 minutes.
You gotta love this place!
Good luck,
Vin
1 - 5 of 5 Posts
