My headlight combo switch works fine, but is loose to the point where a slight bump causes the lever to drop and turn on the high beams.
Is there any way to tighten it up?
Les
I'd check if the headlight switch is held together by bolts or pop rivets. I had some success repairing a windscreen wiper switch that could be unscrewed. But if not (more likely), I'd look for a replacement switch and wouldn't mess with the faulty one until a good one is in the car.
Some photos of of the combination switch here: Combination Switch Clean/Lube. However, I didn't go into the headlight section as that part worked fine. IIRC, the headlight part is riveted together but that doesn't mean you can get inside and put it back together with new rivets or screws/nuts. If you do, take photos for us!
