I have a not-yet-running 84 Spider project in the garage. The car came with a spare engine. The engine that is IN the car went through an electrical fire but shows no obvious signs of damage. The spare engine came out of a donor car that might have been a bit beaten. I am getting to the point where I need to decide if I should stay with the engine that is in the car (and may be damaged due to the fire) or switch to the spare engine. I would like to do a compression test on both engines. I just read that the compression test should be done on a hot engine but at this point there is no way I am even close to being able to start this engine. Do I have to get the engine cranking to obtain useful compression info? Should I assume that the engine in the car was damaged (or NOT damaged) from the electrical fire? The fire got hot enough to warp the hood and bubble the paint on the passenger side fender. The wiring harness under the hood is mostly cooked so cranking the engine over might be tricky.
Thanks Much,
Rick
Southern, NH
Thanks Much,
Rick
Southern, NH
