update on '83 Spider no spark
Thank you for getting back to me so soon, Eric.
So the at the battery the voltage is 12.78V and on the power block on the drivers side inner fender, I measured 12.77V. During cranking, the voltage at the power block was 10.9-11.0V. I checked the pin 4 to 5 voltage again on the ignition ECU and it measured 9.88V during cranking, and the spec is 6-12V. (My copy of AR Engine Maintenance Manual, L-Jetronic, 50 State Version did not instruct to measure while cranking, so that's why I got 0V when I measured it with only the ignition on). Still no joy.
Checked the throttle switch and got the required 0 ohms closed and infinite resistance when open past the click. Got 12.7V at the coil #1 lead with ignition on.
