Just had my transaxle rebuilt with new synchros lightening of gears, etc.
Clutch was beginning to slip so also had it relined (single plate). When I got the units back and installed had a whinning in deceleration in gears 1 to 4. 5th was O.K. Shop said send it back so I did, 4 months later finally received the gearbox back, they redid the stack-up to pinion. Any way now I have the unit back in the car and can't get the clutch to work. Replaced the slave cylinder the first time it was out. Yesterday I replaced the master cylinder but still have the same problem. There is no resistance to the clutch pedal at all, falls right to the floor. (the clutch was always heavy) I've power bled the unit a few times, no air. I can feel the clutch fork moving just a 1/4 of an inch or so and then hitting resistance. I just removed the fork again but it seemed lined up on the throwout O.K. Can move the fork back and forth manually and hear a slight clunk when it comes to the end of travel. If there were air in the lines and I pumped the clutch pedal at least I should get something, right? Could this be a stuck clutch plate? I can engage all gears with engine off. ( no puddles of fluid either)
Could the plate really rust up after just 4 months?
Anybody got any suggestions?
Baffled
Will
Baffled
Will
