I can't figure out my car. I'm leaning toward some sort of fuel delivery issue, possibly gunk in the tank. I don't have a fuel pressure gauge but Harbor Freight has theirs on sale for $20, so probably a sound investment. I tried Greg Gordon's technique of using a cylinder compression gauge, but that ended... poorly. FYI, the car sat with minimal fuel, stabilized with Seafoam, for many months. When I purged the tank it was black. No solid material though.
ANYWAY, the car runs so roughly (cold and warmed up) that I'm worried something is going to explode, break, or otherwise cease to operate. The last time I drove it any measurable distance, about 3 weeks ago, it died when I lifted the throttle. No sputtering, no complaining, it just shut off, then wouldn't restart for many minutes.
I've checked every vacuum line, the AFM snorkus, the plenum connectors (a couple were in fact loose), installed a new air filter, cleaned and regapped the plugs, adjusted the timing, changed the oil, tested the plug wires, cleaned grounds (basically Greg's entire L-Jet walkthrough) and even did a dance to the snake god.
I have NOT yet drained the fuel and pulled the screen, or cut open the old fuel filter to check for crud. The reason is dumb - I don't have a suitably sized container to put the fuel into. I'm guessing there's about 3-4 gallons in the tank. I also can't seem to hack through the filter casing. I clamped it and sawed until my arm fell off, and barely nicked it. Must be made of adamantium.
At this point, barring some diagnosis with the fuel pressure gauge, I'm left with taking it to the mechanic, unless anyone has some mystical or clairvoyant insight. Maybe I can get some video/audio of the thing this evening.
