I see traces of orange Permatex, so someone tried to fix this before.
You could do this yourself if you have access to good safe place where you can jack the front of the car up.
Make sure your car is safe to get under, first and foremost.
Jack stands required.
Drain the oil and drop the lower part of the pan.
Thoroughly degrease both surfaces where the gasket seats.
Brake cleaner, carb cleaner, engine degreaser or whatever you choose to use.
Install a fresh gasket and, yes, add some washers where the previous owner left them off.
Put it all back together and that should help with THAT oil leak.
Be advised, Alfas leak oil.
Like my Alfa buddy said, "If it's not leaking oil, its out of oil!"
Buying a used Alfa is usually an adventure in chasing down and fixing some issues.
Once they are sorted, they are great cars!
Drive it and enjoy it!
I'm sure some other folks will chime in.
Good luck with your car.
