1 - 2 of 2 Posts
'78 Spider fuse schematic
Does anyone have a picture/diagram indicating the correct location/size of the 10 fuses under the dash of my '78 Spider?
I am in the process of rewiring some old connections and want to be sure that I start with the correct baseline. My tail/reverse lights and indicator lights are not working, and the Hi/Lo headlights seem to have a mind of their own - sometimes one works, other times the other!
Thanks in advance for any help!!!:D
Wiring troubles
The fuses are all 8 amps. The parking lights and turn signals are not on the same fuse, however grounding is always an issue. It he parking lights, headlights and high beams are intermittent then it's probably the main stalk.
Hope the diagram helps.
Bob
1 - 2 of 2 Posts
