21 - 26 of 26 Posts
I know you said you've replaced the plugs twice but what you are describing is exactly what i experienced with my SPICA 2L recently. Brand new NGKs, i noticed erratic pulsing when using the timing light. You might try using the timing on each wire and see if you have a consistent pulse.
BTW, the Centerline dizzy i have uses a Pertronix module. While I've not had trouble with the dizzy i have had a number of Pertronix go bad on me....
There have been stories of bad Bosch coils made in Mexico. A failing coil could cause your symptoms. What coil resistance is specified for your distributor?
Have you checked for arcing spark? You need to do this in a pitch-black environment. At night, lights off, a heavy blanket or tarp over the engine compartment. Look for arcing at coil, dizzy cap, along secondary ignition wires and their connection to the spark plugs.
Discussion Starter #24
Thanks for the comment - what was your solution? Another set of plugs?
Discussion Starter #25
My coil has about 1000 miles on it. It's the blue Bosch from Centerline.
My diz is a Marelli S103B. I don't know the recommended resistance.
21 - 26 of 26 Posts
