I am working on a 1977 spider that was changed to carbs with the aluminum spica to carb intake adapters at some point but the car has been sitting a long time and the gas tank was junk inside so I have decided to run an earlier bottom feed tank and mounted a low 2.5 to 3.5 Mr. gasket 42s pump 12" from the tank outlet thus not needing the in tank and regular pump but wanted to know which + line ( in tank or under the car) should I use to power up the new Mr. gasket pump or does it not matter? Does the under the car pump turn on when the key comes on or does it wait to power up once the car is cranking over? The pump that I am using is a low current draw and has a filter before the pump and right before the carbs as well and I am not using a return line to go back to the tank .and I don't think that I need to fuse the pump near the pump but will if others feel that I need to fuse it. Your thoughts on this matter would be appricaited.
