1 - 10 of 10 Posts
All - I'm still trying to find the rear guibo for my Alfetta. Most places say "Inquire" or "No Longer Available" or "Out of Stock". Any help here? I know that they are expensive, even when in stock!
Has anyone found a way to modify the other Alfetta rear guibos from subsequent years to fit these early years? I know Alfa made many changes to the driveshaft during the Alfetta run. Of course, it seems this year is the most challenging to find!
Thanks!
If you compare an early to a late is the little dog ears that sit into the hole. The later one does not have those. You will have to see if the late one will even fit. I don't remember which one has the rear seal with the grease in it.
Have you spoken to Larry at APE about a retro fit? You will need the flywheel, rear yoke and the entire drive shaft to change it over.
Thanks!
early discs have a different bolt pattern.....I have a late model driveshaft available.
I asked last week and Highwood has a rear, they want 160 pounds for it, plus shipping and I assume vat, of course. You should take up @nickypp on his offer, helped me out big time.
OK Parts in Germany seems to have what you need.
Best to email them to be sure.
See link below.
I was searching Alfetta parts on eBay.com.au only yesterday, and saw a few adverts showing the early donuts eg ‘up to 12/75’ from Italy, for example this one (seller bebricambi). maybe they have others too.
1 - 10 of 10 Posts
