Sent block to machine shop to remove hopelessly stuck pistons and liners, must have left one connecting rod bolt in due to clearance, came back without it.. Can anyone help? I also need four or a set of lock tabs for the nuts.
Thank you..
I use lock tight for the connecting rod nuts instead of lock tabs. I probably have a few used connecting rod bolts but, would have them checked for cracks.
Yes, I should have specified, its a Normale, only need one. Unless you recommend differently. And still waiting for help..
Kuni, just came through, very generously. I'm all set thank you both VERY much.
epp
