1 - 5 of 5 Posts
I found this in a box from a long time ago...approx 40 years. I was keeping it back for my engine if I ever needed one.
It has 9 tooth gears. The oil relief piston is new as you can see as is the spring. The bore is smooth. This comes with the gooseneck and a spare bottom housing.
A new pump is $560 from Classic Alfa (out of stock) plus $150 for the pick-up. $710 and that doesn't include the bottom housing.
$750 (firm) plus postage.
View attachment 1675555 View attachment 1675556 View attachment 1675557 View attachment 1675558
View attachment 1675559 View attachment 1675560 View attachment 1675561 View attachment 1675562
Which bottom housing is the spare? 750 (short), 11t (101 1300), or 9t (101 1600?)
Jim
Jim
Great question. I never considered anything else but a 9 tooth. So I took apart a spare 2L oil pump and put the two gears in the housing. The gears turned freely, so it is for a 101 9 tooth. If you need measurements, I can provide those for the asking.
Yes, this one is a parts pump. Made from either a 105 or 2L upper. I often build pumps from many different version components to match customers needs. The 9 tooth straight cut gear set for a 2L does not fit a 105 pump unstepped main shaft, so if this one has straight cut gears from a 2L pump, in the studded 101 type lower body, it had a 2L upper, and it is not even close to mechanically correct as a high speed "veloce" pump Chris.
Given what you have said, then what I have is not what I thought it was when I picked this up some time ago. The best thing to do is to pull this off the market. This is no longer for sale. Thank you for the advice.
1 - 5 of 5 Posts
