Hi
I have a 75 Turbo, which I´m restoring.
When I bought the car I had a similar problem, the car didn´t want to start, and the problem was dirty injectors.
They were professionaly cleanned and the car started almost immediately.
But last sunday, when I was leaving home for a road test, it runned 50 meters and it shut down...
I chequed everything and the problem is that there isn´t spark on the plugs.
I removed the Intercooler and checked every connection. At one time it wanted to start and I can tell that there was spark because I had a plug conected to a HT cable and I saw the spark.
So I thought that it was solved and put the intercooler back on his place, doing all electric connections.
I tried to start it and there was te same problem again, NO SPARK...
I checked everything again, but I couldn´t find the problem...
What can I do?
What do you recomend to check?
What is necessary to have spark on the plugs?
Regards
Carlos Oliveira
What can I do?
Regards
Carlos Oliveira
