1 - 19 of 19 Posts
Hi Guys
I have just purchased a alfa 75 twinspark which for the most part is in good condition :)
But there is one issue that I was hoping someone could help with
When turning left with a decent amount of lock the front left tire starts to rub against what I believe is the inner stone guard and creates a loudish noise
The Mags are factory 14" with 195/60 tires on all 4
Has anyone come across this problem before and know how to fix it ?
Thanks in advance
Nick
Thanks for your responce
Its going up on the hoist on monday so I guess all will be revealed :)
There's a couple of things you can check before Monday.
Ground clearance, has it been lowered? What is the clearance under the sump on flat ground?
Wheelbase. Has it been hit in the front left?
Hook a tape measure on the back of the rear rim at hub height and measure to the back of the front rim. Do both sides and add the results. It should equal 5020mm (2510 x 2).
Probably the front castor rod rubber bushes are shot or, worse, the bolt is loose and about to drop off.
EEK!
Yer this happened on one of our 3.0's, my mums car, lord knows how long she was driving like this for, the nut wasnt found.
I don't think its been lowered but that could explain it if try
I will check over the car on Sunday when I have the time and see what I find
Hey All
Went to the mechanic on Monday and he said a alignment and getting something to hold back the side skirt should sort it out ,I got some tapper type screws from a repair shop which should hopefully do the business
Now my next question is ....... whats the easiest way to find out were a coolant leak is coming from ?
The 75 is going through a reservoir full of coolant every couple of days so something is up
Lastly I put in 42 litres of 95 octane today how many ks should I expect to get out of it if all is well . Half of my run is motorway and the other 1/2 is traffic
In the 33 I would get around 450/500 if I drove like a nanna
Cheers
Nick
G'Day Nick,
With the eyes. ;)
Seriously though, most of it may be coming out the cap, mine maintains a level somewhere just below halfway.
Well I get a steady 10l/100km day on day out except for country cruising when I can get 7.5l/100km.
I know of someone else who averages 8l/100km but he drives like a nanny.
It's a 49 litre tank and I tend to fill up at about 40l so I get around 400km/tank but would get about 530k/tank on the open road but could squeeze 630k (47 litres).
ahah yeah eyes help
I only ask because it didn't like it was leaking from the top , usually its pretty messy if it does and looks like a pigsty
But when it has got pretty hot its taken a good 40 mins or so to get to that point maybe theres a minor crack or lose connector
Also I forgot to ask do you run your 75 on 91 or 95 ? assuming you get those octane ratings in australia
Nick
G'Day Nick,
With the eyes. ;)
I've actually been using the 95 Plus 5% ethanol blend from United servos for the past 12 months without any dramas. We've been using it in our other 2.5L before the timing was retarded and it had no dramas (91 caused knock, 95 was perfect).
ROCK ON
R~R
Discussion Starter #13
Thanks guys
Craig your site is awesome , when its not crapping down with rain il go have a look at the o2 sensor
Ok time for newbie questions no# 113
The car came with additional springs which measure 36 cm in height from the start to the top of the coil , they are red and have the marking 05-005 rear
I think i know what the rear bit means :rolleyes: but the rest is a mystery to me
Does anyone know from the info given if they will lower the car or just make it stiffer ?
I would post pics but my camera is in the US of A with my olds
Cheers
Nick
They're probably lowering springs, especially seeing as they're painted red:D. It's hard to say how much without having a standard spring out of a car to compare with, and unfortunately it's not as easy as comparing the free length because it depends on the stiffness as well. There's one easy way to find out though.........:D
Scott
Discussion Starter #15
Scott
Unfortunately I don't have the space or the tools to do much with the springs at the moment
Another note does anyone know the socket that you need to remove the lug from the oil pan ?
it seems 24 m isn't big enough :(
Discussion Starter #17
Cheers mate
The 33 I had used a hex-key so it was just a little bit different under there :rolleyes:
Hi Nick...I've got some Jamex springs knocking around the workshop if you want to compare!
PS: who's doing the work on your car?
Discussion Starter #19
Hi Mike
Could be a idea at a later date
Im not to bothered with the springs at the moment because I don't have much time to sus it out
I am just taking the car to the usual suspects
Pete on the shore and tony in onehunga
1 - 19 of 19 Posts
